SOTA activations in protected areas in Switzerland
In Switzerland, there are hundreds of protected areas, which are split into many different categories. As a SOTA activator, you will be confronted with these protected areas sooner or later.
Suddenly, you end up at a information table. A feelung tells you that you should study the content. However, time is limited, you’d like to get to the summit and finally start playing radio…..
You can find a short guideline to Swiss protected areas with further sources of information, hints and rules in this link.
Thank you Paul, HB9HHF and Patrick, ONB4BCA for picking up the translation.
